Anyone went from 23t to 24t on a warrior ?
if so, does it make a difference on acceleration ?
the point is I want to reduce the angle the chain has to do around the chain tensioner. I was looking for a high pitched noise from the chain case, so I removed the case cover and made the track spin. The sound is comming in fact from the chain. As I changed the chain tension, the sound also changed. The angle the chain has to do is very sharp. I rode rx1's and you don't have that sound or very slightly. (they have the 24t).
All the bearings in good condition, new oil and the required shims in place.
