Warrior with picks???
sleddheadd
Il
i was talking sleds with a buddy yesterday, comparing our warriors and he said he had no picks in his.... i bought mine used with a M010 suspension with picks in it, he said his dealer told him he couldn't put picks in unless he changed the drivers.....his sled is all stock.... is this true? because i am thinking of buying his sled for my wife and i would like to get picks into it for her.....
As long as the track lugs are no longer than 1.25 and the picks are not more than 1.4 it can be picked with the stock drivers.
Yep, no problem.
108 woody's Megabytes 1.325's in my Warrior for 3 years.
All is well.
Stock drivers will work fine. Keep an eye on that track tension. You may also consider installing 1/4" alum. strips on the rub rails too.
Ditto. It is a must to add the strips if it has an exchanger in the rear. I have the M10 136 on my sled, I had 190+ studs, way to many, I had to take out every other one to reduce the push, now it rocks. PM me with any questions I can help with.
