I WAS WONDERING IF IT WOULD BE POSSIBLE TO
CREATE A (WARRIOR FORUM) , INSTEAD OF BEING IN
WITH THE RX1 SHORTY.
WHAT HAPPEN TO THE SRX INFO?
JUST WONDERING..
ANYBODY WITH A WARRIOR ABLE TO GET HOLE SHOTS ON THE ICE?
I WOULD LIKE TO GET MINE A LITTLE BETTER.
I'M GOING TO TRY TO GET ON THE CHAT NEXT WEDNSDAY NIGHT.
I HAVE SOME SOME TEST RESULTS AND SOME HELP FOR ANYBODY
THAT IS INTERESTED FOR LAKE RACING IN 660 AND 1000.
WELL I MEAN I HAVE SOME OF MY OWN RESULTS.
BLACK WARRIOR WITH 108 STUDS.
JUST WONDERING..
LazyBastard
1) DON'T SHOUT!
2) Reason is that there is no substantial difference between RX1 and Warrior. Its just a longer track. What applies to one applies to the other.
Buckeye
- Lakes Region, NH
Racing
If you are going to race 660', you will need alot more than 108 studs. And I agree with LB the 2 machines are the same.
I RIDE BOTH SLEDS (2004) AND THE WARRIOR SEEMS LIKE ITS
DIFFERENT. THAT WAS JUST MY OPPINION. THANX.
WHAT HAPPEN TO THE SRX FORUM???
WITH 108 STUDS ON ICE I ONLY SPIN FOR 6 INCHES.
I WAS TRYING TO FIND OUT WHAT ROU GUYS ARE INSTALLING.
I'M PUTTING A TURBO ON THE WARRIOR THIS SUMMER.
ARE YOU GUY'S HOOKING??
C U LATER
C U LATER
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I have 126 and I don't hook on ice worth a sh*t
But I didn't stud to hook, but to stop
mighty, if you were in bronson mi for whitestar auction you
should of brought you sled with you. we were on the ice
comparing sleds. i live 5 miles south of auction.
when i put my studs in my track on the warrior i assumed that
if i could hook up out the hole on ice that there was a good chance
to stop on ice. what pattern did you use to stop with??
ther is a big difference between the shorty and the warrior..
with the cpr stage 3 clutch kit i lost midrange and top end.
will be in quincy mi for tip up feb 14,2004. ther is great ice racing.
all the big boys will be there. if you live by lansing it's a straight shot
off of 69. cu later
off of 69. cu later
HEY MIGHTY, YOUR NOT MAD ARE YOU/
