doo_man
Just installed Water Temp Gauge, just need to install sensor in coolant lines. Followed instructions on-line here, was just wondering if it makes any difference if I install the sensor just below the thermostat housing (just becuase it works better for my install) Tried following the lines in the service manual and not clear of path of coolant exactly? Will I get proper temp reading here?
Nos Pro has a nice one get ahold of him.
gsxr-rider137
i have just recenlty installed a water temp gauge in the cockpit and was looking around to see where to istall the temp sensor, when i saw a t-fitting from aeroquiment so i could use the stock idoit light and the gauge. i plan on ordering the fitting mon/tues.
Mrsrx
- Jan 19, 2004
- Central WI
- 1997 Polaris XCR (bought new has 4300mi)
2002 Yamaha SRX
2005 Yamaha RX Warrior
2007 Yamaha Vector
2012 Yamaha Nytro XTX
2022 Polaris 850 Switchback XC 146
2021 Can Am Maverick X3 XRS TURBO RR
- Central WI
i put mine under the thermostat house it works great. sorry for my spelling i am from sweden
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
mrsrx said:i put mine under the thermostat house it works great. sorry for my spelling i am from sweden
Mine too.
IMO the main reason to install a guage is to see what temp your sled typically operates at rather than an exact reading. That way if you start to see higher than normal temps you can take steps to lower it.
Warrior, what temp does the idiot light come on at and what is normal temp?
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
fatchance said:Warrior, what temp does the idiot light come on at and what is normal temp?
I've never had my warning come on since I installed the gauge so I can't say. Others have said 210F.
My normal temp reading is 165 - 175F
Thanks warrior. I would think these temps would be the same as the Apex.
Len Todd
On my 04 rx-1 the temp warning light comes on at ~ 215-220 degrees F.
It normally runs at ~170-190 degrees F. Anything over ~200 degrees, I am looking for loose snow. I have fiddled with snow on the running boards when temps are ~200 and it works very well to add some snow on the boards. Even if you only do one side.
otis
Check this post it has excellent pics of the install on a Rage which was exactly like how I did my RX-1
http://www.ty4stroke.com/viewtopic.php? ... gage+guage
Otis
Otis
