Water Temp Gauge
yzviper366 said:
Here is where mine is its thebine with blue numbers very clean looking I don't have pics of the adapter in the hose I can get them if anyone wants them it'll b a day or two tho.
What is the brand name of your Boost and A/F Gauges? Where did you get the bracket to mount both of them?
Just purchased the Koso temp gauge with 26mm adapter today! Where's the best place to get the power from on the sled? Any and all install pics welcome so I have less chance of messing something up!
Not rushing you at all yzviper366, I know your working. Just looking for pics from other peoples installs too if they don't mind. Cheers.
Sorry I got a pic yesterday forgot to post. Here is where I tapped into the coolant hose. And I took power from the 12v aux plug wire. I believe green is the positive one.
I will but it won't be much its all bunched together with electrical table very simple tho. Just cut and splice positive wore to the green wire and negative to then white . Easy work.
View My VideoHad mine on for a couple years it works great but can be a little hard to see in direct sunlight. I made a aluminium mount that fastened behind the gauge. No regrets , works very well.
