Water Wetter?
I was doing a little reading on the Redline website, maker of Water Wetter.
Check the Tech. info they provide: http://www.redlineoil.com/products_coolant.asp
After looking here, I'm not all that sold on the product. My guess is that it may reduce the temps by about 5*F by putting this product in.
So will a couple drops of dish soap.
OK GUYS I WILL GIVE U REAL WORLD ADVICE AND TESTIMONY ON WATER WETTERS MOST WORK A LITTLE INTIALLY BUT TEND TO FADE AFETR A USE OR 2 IN OUR RACECARS IMO
Now if u guys want to use the best stuff IMO but a true great working product that last i will give u the info i sell it and have it in stock.It is a little pricy to some but u willl have enough to do 15 qrts of fluid It is $25.00 a bottle plus shipping better priceing on more than 1 It is called MotorMax and it works! It generally has dropped temps in the 20 degree range i have seen 30 but coulda been conditions and luck This stuff has ALWAYS worked and worked with exceptional results not just 5 degrrees there is enough to do 4 sleds with the mount in 1 bottle try it u will not be dissapointed let me know if i can help u with some Dave
Did you say water wetted??? :moon:
Familyman,
I bet that sled never overheats, it is genuinely "water cooled"! :D
I got my WW, what is the best way to put it in? Should I just put in into the reservoir, or take some out, mix it in and pour back into the resovoir? Any suggestions?
Just pour it in before you ride.
It'll mix on it's own.
I have heard that watter wetter type additives are not anti-freeze so be careful and check what temp you are good to after it mixes in...I personally would take some antifreeze out and add it in then otherwize its gonna come out the overflow.
