Less threads keeps skis on the ground, the reason I know is I recently removed my transfer rod, changed nothing else and it wheelies like crazy, which is what I was after. Do a search on transfer rods and there is a ton of info...I have a 2011 apex SE with floats. I use snow trackers. Front shocks at 85lbs. My weight transfer coupling has about 1 1/8" of thread showing. I get some ski lift.. Would less thread showing make it better or worse for ski lift?
Thank you.. I wasn't sure if more or less threads put more weight on skis.. I have 1.5 inches of thread showing and I have snow trackers on stock skisLess threads keeps skis on the ground, the reason I know is I recently removed my transfer rod, changed nothing else and it wheelies like crazy, which is what I was after. Do a search on transfer rods and there is a ton of info...
