stock rx1 . what are the weight transfer adjustments . i want to put more weight on the skis . i find its a little squirelly when on the throttle. i have changed the sway bar links to the longer ones which helps in corners but alond the straights the steering is to light . any help appreciated
LazyBastard
Control rods. The big nuts on the diagonal bars near the back of the skid. You could also tighten the straps up a bit.
HEAVYD
You turn them counter clock wise i believe, help me
out if im wrong LB
out if im wrong LB
what exactly does this do ? does it pick up or let down the rear axel ? i was just looking at it trying to understand the concept but i am a little confused. so not sure whether going the right way
HEAVYD
O K, i looked it up, it is counter clockwise. you want
to shorten the amount that the rod can travel downward. the body is trying to push down to lighten the front end under throttle and this prevents this. make sure you adjust both sides the same amount. if you tighten the 10mm bolts on the
front straps you can also put more pressure on the skis by compressing the front shock and lighting spring pressure on the front of the skid
