Whaat happened to my blower. Anyone have a stage one F/S :(
stephenpen
Barrie
I pulled off the lake and heard a squeeling sound. I shut the machine down and there was no more boost after that.
The impeller is sloppy and does not turn when the machine is running. The supercharger oil is full and has very little miles on it.
What happened ?
Is this something that can be fixed, if not how much is a new blower worth.
Does anyone have a blower for sale or now where I can get a good deal on one.
Ya I checked the belt. I wish it was that easy and cheap.
Here is a pic of the impeller
I've been riding the machine for weeks now with no problems.
I did not do the oil change myself. How do you prime it ?
Do I just remove the upper line till it starts spitting oil.
You only need to prime it the first time it starts, or if you disconnect the supply line. To prime you loosen the oil supply line at the top of the charger and put a small amount of compressed air into the oil tank until oil starts coming out of the top fitting. Make sure to plug the vent when you pressurize the oil tank.
