chadman
What tooth anti ratchet drivers would I need for my 07 apex rtx? I was thinking of getting Whal bros.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
what size track. if your stock drivers are 9 tooth then you need 9 toth for stock track
I have the Whal brothers drivers and i run a 1.25 pre-drilled rip-saw. Not a ratchet since I added them. A little noisy and some vibration, but no ratcheting.
chadman
I have the stock ripsaw track with studs. I have to open the windows and fully clip the track.
irondog rtx
go with the cobra camoplast 1.25 all windows open nicer track I have never liked the ripsaw you can go with 8 teeth drivers and gear up on chain case this gives more room under the tunnel and away from guards
