Skeeterzx225
This is my first 4 stroke snowmobile, what are the steps needed to properly "Summerize" the sled? I'll be storing it in my garage, so I could easily start it up for a few minutes every month, is that sufficient or is summerizing necessary?
gun nut
winterize
Isn't that in the owner's manual?
SledFreak
- Feb 7, 2005
- Ontario. Canada
Grease the suspension and put Seafoam in the gas. Run the sled for 5min and your done. Wash and wax and charge the battery every 2-3 months...Skeeterzx225 said:This is my first 4 stroke snowmobile, what are the steps needed to properly "Summerize" the sled? I'll be storing it in my garage, so I could easily start it up for a few minutes every month, is that sufficient or is summerizing necessary?
ualav8
well......
in summary, i'd say they were way better than 2 strokes.
i hope this helps
i hope this helps
Skeeterzx225
SledFreak said:Grease the suspension and put Seafoam in the gas. Run the sled for 5min and your done. Wash and wax and charge the battery every 2-3 months...Skeeterzx225 said:This is my first 4 stroke snowmobile, what are the steps needed to properly "Summerize" the sled? I'll be storing it in my garage, so I could easily start it up for a few minutes every month, is that sufficient or is summerizing necessary?
Thanks, I like how it doesn't require fogging anything
Skeeterzx225
Re: winterize
I was curious if most folks found some of the owner's manual steps uneccesary
gun nut said:Isn't that in the owner's manual?
gun nut
Good time to put fresh clean oil in. Also make sure bearings are greased. I also spray WD40 on all metal parts.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
gun nut said:Good time to put fresh clean oil in. Also make sure bearings are greased. I also spray WD40 on all metal parts.
X2 on the WD-40. I always did this to my two-smokes and never had any corrosion build up on the motor or any of the metal components. Same on the Apex and Nytro. Both my sled motors look new!
yamahahaapex
Wow sledfreak if it was only this easy
gotta-b-blue
I know it is obvious to most, but for the new guys DON'T spray WD-40 on your clutches. Everything else sounds great.Apex2006 said:gun nut said:Good time to put fresh clean oil in. Also make sure bearings are greased. I also spray WD40 on all metal parts.
frozesolid
- Nov 8, 2009
- Findley Lake, NY
- Pro R Switchy
big guy
I use Fluid Film. It is an excellent product! 10 times better than WD-40 !!! But WD-40 still works.frozesolid said:
big guy
Here is what I do after every season.
Fill gas tank, stabilize gas and run motor. Change oil and filter. Change gear/chain oil. Pull skid clean and grease all wheel bearings and check slides. Grease every zerk. Pull drive shaft bearing check condition, replace bearing or clean and grease. Clean and grease jackshaft bearing. Pull ski's and lube up ski bolts and bushings, Clean her all down.Spray Fluid Film on rear skid and front suspension. I don't fog the motor. My sled is stored in a climatized shop. I don't start my sled during summer. In fall just before riding season I will drain 5 gallons of gas out and replace with 5 gallons of fresh stuff.
I have 5500 miles now. Last year I had all my shocks serviced. This year I am getting my clutches serviced and changing spark plugs.
shanksyamaha
This will be the first time I stored this apex, but I ALWAYS fogged my rx-1 and any other engine I store for an extended period of time. Does anyone else do this, maybe its not needed with the 4 strokes but I also DON'T start the motor during storage, yamaha makes it clear that this is not a good practice.... At least according to them..
mr. shide
I fog the motor on anything that will be sitting for more than a few months, its a quick and simple procedure. I dont use wd40 or fluid film but instead use silicone spray lube. Works great. spray on almost anything you want. prevents corrosion and lubricates/waterproofs. If only everyone knew to use silicone on the machines there wouldnt be a rusty or corroded used sled on the market. even if you haul in an enclosed trailer, there can still be salt residue from somewhere that will pit and coorode parts. back to summerizing, give it a good wash and wax. I prefer to do most of the prevent maint. in the fall but it doesnt really matter, as long as you do it before the snow flys!
