mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Supercharged sled apex
STRAIT VP C16 fuel
Engin compression ratio it 10-1
At 20 # of boost:
With meth injection turned on or off will run perfectly and boost needle is stable
At 24# of boost:
With meth on it does misfire and send a lot of flames strait through the exhaust and make no power and boost needle bounces around a lot
With meth off, it does not misfire and run correctly and boost needle is stable
At 27-28# of boost:
With meth on or off no mather what I do with air fuel or timing, it does make LESS power than 21# of boost and missfire badly (almost sound like a stutter)
Boost needle bounces from 26-29 psi all the time
At 30# of boost, same thing, no power...
Boost needle bounces around the 27-31# all the time
Plug gap is 0.020"
I use the SDS-EFI ignition coils.
Air fuel ratio are in the mid 11' range. but tried low 11's to low 12's with same results
STRAIT VP C16 fuel
At 20 # of boost:
At 24# of boost:
At 27-28# of boost:
Plug gap is 0.020"
