What is causing this?
sleddog66
DeKalb IL
I got home from a trip, approx 700 miles. The tips on the front of the rails are almost junk. I had the track slightly looser than the book says. No racheting of the track. Alignment seems ok, although one side of the track does require more force to deflect 1.25 inch that the other. It is aligned evenly on the rails when I run the track. All clips seem OK. I do run this thing at high speeds, but that is why I bought an Attak. I have never had a Polaris do this in 25 years. Can anyone tell me what caused this?....What is the fix?.... Do I need the anti stab wheels? The machine is a stock 2007 Attak with stock track and stock drivers.
Another.....Oh ya, both sides are doing this about equally
Track is slapping the rails. If you run it this loose, I would suggest an antistab kit. Spear a rail tip with your track and it'll ruin more than just your day.
Thanks for the info. Maybe I will look into a whal bros. I am really not running the track very loose, but I guess the mono is more prone to this.
Mine was doing a similar thing but also wallered out the rivet holes and I lost one. When I replaced it I used a machine screw with loctite and a bigger washer. It's held on fine since then.
