SnowBandit
- Jan 31, 2004
- NH
- www.slednewengland.com
- 2009 Nytro xtx
I had my hyfax wear all the way through right in front of the front wheels. Was I running the track to loose and this caused it to wear here? The rest of the hyfax is ok, closing in on the wear line but not through. I had the track pretty loose it would ratched under heavy acceleration...
Next question is I worn right through the hyfax and worn down the rails a bit... Is it ok to put a new set on and keep riding? Or do I need to replace the rails????
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
put new on it and ride it
fireman1069
It should be fine as long as the rail isn't damaged or cracked. Just put new h/fax on.
gordy
will be just fine. how many miles on hyfax? mine wore out same place at 3800 miles.
SnowBandit
- Jan 31, 2004
- NH
- 2009 Nytro xtx
1500 miles thats it... Kinda of ticks me off as I thought they were fine till I droped the skid to do the Y pipe replacement... They worn down a good amount of the rails still have a little of the edge that holds the hyfax left but looks like I will be buying new rails shortly...
cat hunter
Put the extra wheel kit at the front and the problem is solved!!!
quebecmoutainrider
dumb question.
do you have snow scratchers on your sled..as far as the rails...just rub them with sand paper ,,to make sure there is no sharp edges..to cut the slides..the problem you might have now..unless you change the rails..is when you turn.. the track pushes on the side of the rail.then travels down the slide..so watch for this..could cut through..I think the real problem is...that the rails turn up too fast..so when you hit the bumbs,they really hit hard there..and when you get new rails(like iceage..less turn up),get powder coat..the ice and snow stay off more...and we all know we could lose some weight on these things..
SnowBandit
- Jan 31, 2004
- NH
- 2009 Nytro xtx
Re: dumb question.
Ok what is iceage???
quebecmoutainrider said:do you have snow scratchers on your sled..as far as the rails...just rub them with sand paper ,,to make sure there is no sharp edges..to cut the slides..the problem you might have now..unless you change the rails..is when you turn.. the track pushes on the side of the rail.then travels down the slide..so watch for this..could cut through..I think the real problem is...that the rails turn up too fast..so when you hit the bumbs,they really hit hard there..and when you get new rails(like iceage..less turn up),get powder coat..the ice and snow stay off more...and we all know we could lose some weight on these things..
quebecmoutainrider
iceagemfg.com this will get you to the site...
grumpysanta
pull limiter strap up one hole
