Jasonjmccoy
- Mar 22, 2019
- Plymouth, WI
- 2012 Nytro XTX
I installed one of the tow hitch bumpers that has reinforcing material that is riveted to the tunnel. I'm looking to put an ice auger carrier on it that simply uses U bolts to clamp the carrier to the rear bumper so that bumper is supporting all of the weight of the auger and the mount, probably close to 40 pounds. Just wondering if that's going to cause issues over time or if it can handle that weight? Seems if you can pick the rear of the machine up by it, that it should be fine but not sure.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
My nytro has towed more times than I can count. bumper is perfect. I think the joke was at the time they came with a yellow strap to match the average sled that you would be towing
you might be ok. i had a rack on my apex xtx and it kept working the rivits loose on the tunnel extension and i only had a 1.5 gal klopin can and mount on it. rack finally broke so i left it off.
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
I have an XTX with a rear rack and I keep a 1.5 gal fuel jug plus 10 lbs of guear with no issue. That is close to 25 lbs. The prior owner put a 2.5 gal jug on the rack and gear so est >35 lbs and it cracked the weak point on port skid. Yami made a bracket plate after 2012 that I installed and no further issues. The bumper hitches move weight to the upper frame so I suspect 40 lb is fine.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Ive towed allot of Polaris, and a couple of skidoo’s , oh you mean weight. LOL
mbeaunh
- Sep 18, 2016
- N.H.
- 2013 Nytro XTX, 2014 Viper RTX
Not sure what kind of hitch you installed, but I put a Yamaha bumper/hitch on my 13 xtx and I towed an Equinox Snocoach (over 300 lbs) for 4 years without any issues.
