welterracer
I was checking my belt and clutches and found some slight play in the secondary bushings that touch the shaft..
Basically i can slightly wobble the secondary clutch on the shaft..
Whats the allowable amount..,?
THanks
Brian
THanks
Brian
copo427ss
are you talking the whole clutch itself wobbling on the shaft, or the clutch sheaves wobbling on the clutch? when my bushing came off the back. it threw my whole clutch off and was binding on itself. it vibrated pretty bad, but there was also no bushing at all in it. most dealers have the bushings in stock.
yamadog1
bushing
welt a small amount is normal, turk told me he has never changed one,
there easy to put in also to drive out or press out,
welterracer
after i took it off. i realized it has no bushings..
I guess there is nothing wrong with it..
SledFreak
- Feb 7, 2005
- Ontario. Canada
welterracer said:after i took it off. i realized it has no bushings..
If you want to eliminate that whole issue. Grab a set of stock clutches off another sled and try it and see what it does. If it's still there, then you need to look else where.
favarcat
I changed both of mine this fall. There was alot of play and a big difference with the new ones in. Also changed the primary cover bushing. My ramp bushings were also wore, replaced those. 13,150 miles on sled.
8ER-17688-00-00 ramp buttons x 3
90384-38243-00 secondary bushings x 2
90380-28237-00 primary cover bushing
ICULOKIN
I WAS WONDERING THE SAME THING,BUT ONLY HAVE 3100 KMS ON MINE.FRONT END BUSHINGS ARE SHOT THOUGH.
Nealj4
- Dec 1, 2024
- Wiarton , Ontario
- 2017 Sidewinder STX 137
I am curious about his as well. With my secondary dissassembled I have a slight rock or wobble in the sheave and helix bushings. I mic’s them and stub shaft is 1.495” and helix is 1.500 and sheave is 1.502. So basically .005-.007 of play in bushings. Is that acceptable??
Put the clutch together without the spring and observe the play or lack thereof.I am curious about his as well. With my secondary dissassembled I have a slight rock or wobble in the sheave and helix bushings. I mic’s them and stub shaft is 1.495” and helix is 1.500 and sheave is 1.502. So basically .005-.007 of play in bushings. Is that acceptable??
My rule is that if the teflon coating is coming off and you can see the bronze, then replace.
These bushings normally last a long time.
It's the buttons that need inspection for wear and hairline cracks. Do not use aftermarket.
Nealj4
- Dec 1, 2024
- Wiarton , Ontario
Thanks 74 Nitro. That makes a lot of sense. Doing that mine has basically no play. Teflon is still on bushings but buttons are cracked and flat. Have new ones arriving tomorrow.
