yamahahaapex
I noticed there seems to be a bit of play in the secondary which sounds like its quite normal on this site after doing a search. I also noticed there is a washer that is on the secondary bolt that is between the head of the bolt and the secondary. Basically in between where the play in the secondary is found. Is that right?
yeah, it's right. It's a "floating" clutch
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Clutch freeplay spec is 2-3 millimeter.
When you measure clutch offset, spec is 15 millimeter +/- 1.5 millimeter.
Yes it allows the secondary to slide in alignment with the primary as the sheaves move.
