What is the color code for Yamaha Red Candy apple?
viper7mi
Michigan
What is the color code or a Dupli-color number for matching the Yamaha candy apple red?
You typically won't find a cross reference for snowmobile colors if they are made by ColorRite. You either buy theirs or find a color that is close.
On the colorrite site is has base and clear for candy red color.....do you guys think the touch up would work without the base?....i dont see how a touch up could use a base .
any thoughts?
Dan
any thoughts?
Dan
It would be a SINGLE STAGE.if it is MET you can't touchup,it will not like good.not sure on the RED A-ARM or HOOD to see if theres MET.if the paint/color is scuffed you can just take clear nail polish and wipe over.they will get marked up again.cheap easy fix.mine are SATIN BLACK and they look new.u can't tell.if i was going to be in the AUTORAMA i would paint.like i said cheap easy fix.
I will check duplicolor for a similar match. Food Fusion has a candy red that looks very similar.
2006 Ford truck Dark terrador red is ALMOST a perfect match. Repainted the A arms on the right side and it was alomost impossible to see the difference. Maybe a shade off at the most.
got a code??
Yes, here ya go.
2006 Ford code JL
Dupont Chroma base , 89668 K (39668 K maybe)
I had them scan one of the parts to get the code plus I had this color on my truck , had to repaint a couple parts due to a big rock and poor judgement. :)
I should be able to get the Blue code on here shorlty.
