chadman
I am buying an 07 rtx and I see some guys are running cr10ek spark plugs and I was wondering what you gain by running them?
blackattak
Made by NGK it is the name of the plug. Supposebly runs a little cooler & suppose to give you 2-3 horses more.
chadman
Can it hurt your motor or void your waranty?
Mikecam
No !
blackattak said:Made by NGK it is the name of the plug. Supposebly runs a little cooler & suppose to give you 2-3 horses more.
actually runs hotter, take a look http://www.spark-plugs.co.uk/pages/technical/ngkjpg.htm
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
10 is the next COLDER plug from NGK..all NGKs heat ranges go from low numbers(HOTTER) to hi numbers(COLDER)....
stock is a 9 and stock plug has only one electrode...the CR10ek has two electrodes...they burn more complete...and make a few HP on dyno...wont hurt anything and starts just as well in cold.
dan
dan
iasledder
Definately 1 range cooler. According to my chart also uses 2 neg grounds over the standard single. I would be a little concerned running cooler. I fouled the hotter stock CR9EB. In all fairness though, this occurred during a cold start attempt, not on a warmed up engine. Gradually fouled one plug at a time until all were dead. Took out, cleaned up and kept as spares.
