rambunctious
I jsut bought an 06 apex ER
it has 96 studs on stock track in the v pattern in the center
i feel this is too few for the HP
I have always had studs on outside of track with no issues
how many should I have total ( 144?)
what length would be good for outside ( 1.45?)
how many ribs/flats are there for a 121" track ( I can't remember)
I am thinking 1 every other flat on outside to supplement the 96 stud V patters currently in the center?
thanks
Ramb
thanks
Ramb
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
I run 144 studs in the middle of both my Apexs 1.325 length and there are 48 flats.
Ported Hornet
144 up the center 1.450"
rambunctious
thanks
any pics of 144 stud patterns?
thanks
Ramb
thanks
Ramb
mikeyd
- Mar 26, 2007
Go to the Woody's web site.
Iceman57
I'm running 168 Woodys Mega Bites.
RedRocket
rambunctious said:I am thinking 1 every other flat on outside to supplement the 96 stud V patters currently in the center?
If you have 96 studs on now and add 1 stud on every other pitch (flat) then you are only adding 24 studs for a total of 120 studs. If you add 2 every other pitch (flat) then you are adding 48 studs for a total of 144 studs which seems to be a minimum for that much horsepower.
I ran 144 up the center on my sled because I ran them on the outside as well on my last two sleds and those were the only studs to pull out or bend. I also find that having studs just up the center does not hurt your turning ability as much.
Here is my setup
I assume your setup looks like this...
