sledfvr
I have an rmi driven turbo rx-1 at 22lbs boost. With the rmi drive I have to run a 51" long skidoo belt. Gates seems to be the most durable so far, but not as good as a stock yamaha would be. Anyone have any ideas?
Jonny Rocket
- Colville, Washington
- 2008 MXC boosted Nitro
Stock yami belt is most durable.
J.
J.
sledfvr
I see that the old v-max 4's have a 52" long belt. Do you think they are as strong as the belts that come stock on the rx-1's from yamaha. If so I may be able to get one of these to work.
deerlodge
- May 1, 2003
- Orr,MN
- www.deerlodgeresort.com
+1 for stock yamaha, I have had it on my turbo for the last year with no problems
shanksRX-1
- Feb 6, 2006
- Pennellville, NY
- 2010 Apex
- Pennellville, NY
I roasted a stock yamaha belt the first pass with my turbo. The belt had about 1000 miles on it. Still I think yammi belts are best. I bought an ultimax xs that is guaranteed not to break for one year but im not sure if it might be affecting my top end performance. Thought I would try it. Its noticeably heavier and stronger looking than a yammi belt. but cost $90
ProstockBenji
- Feb 24, 2005
- Leamington, Ontario
- www.doublediamondacres.com
If the C to C is correct and offsets are right a stock Yamaha belt will take 400hp. clutch set-up "engagement" and "belt clearance" will play a huge role in belt life , The more you slip the belt the shorter the life span of a belt .
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
sledfvr said:I see that the old v-max 4's have a 52" long belt. Do you think they are as strong as the belts that come stock on the rx-1's from yamaha. If so I may be able to get one of these to work.
The old V-Max4s were notorious for breaking belts, don't use that belt. The yamaha 8DN is way stronger.
powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
Belts
I used to run V-Max 4's 800 belt on turbo and it is very good belt and nothing else would stand up like it.
http://www.powderlites.com
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
I havn't tryed the Yamaha belt but Of all the belts that I have tryed , the xs belt has been the fastest for top end by about 3 mph
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
Stock Yami belt
ProstockBenji
- Feb 24, 2005
I have found the Vmax-4 belt to stand up to any racing application . they were the only double cog belts back then .
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
OK - then the V-Max4 guys around here did have their clutches out of alignment, very possible that is.
spray25
8DN
sledfvr
ok skidoo belt only lasted one ride. Gates extreme lasted two rides. Checked alignment and looks good. This sled was dynoed at 382hp. I guess I should try a yami vmax 4 belt. I'd like to get yamaha to build me one as strong as an 8dn, probably have to take out a small loan to do that though. belt needs to be 51" long. 8dn is only like 44. help?
snowy1
thats why I got rid of my rmi drive when I went to the trx, no good belt options, and I have yet to here of anyone having chain case problems.
