gerard143
IS THE WARRIOR CHASSIS AND RIDING POSITION JUST LIKE THE VECTOR JUST A 1000CC MACHINE?
WHAT IS DIFFERENT?
WHAT IS DIFFERENT?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Exact same.
Tork
Yes all Delta 1 sleds are about the same, some minor changes in seat padding. All RX and RS sleds are the same seating wise only apex/
attak and Nytro are different
Bakemono
Doesnt the '05 Warrior have the wider running boards like what the RX has?
Not a big difference, but the wider running boards make a bigger difference than you might think.
Cap'n
Cap'n
Swiss Sledder
Re: WHAT IS THE WARRIORS RIDING POSITION LIKE? LIKE THE VECT
I believe the Vector front end has a slightly different geometry than the Warrior. The guys on here can tell the exact difference, but the angle is slightly different and allows the Vector to corner better. This revised geometry was moved to the Apex/Attak line in 2006.gerard143 said:IS THE WARRIOR CHASSIS AND RIDING POSITION JUST LIKE THE VECTOR JUST A 1000CC MACHINE?
WHAT IS DIFFERENT?
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
When I said exact same I was refering to the riding position.
