What is vibration/shudder at 9000rpm??
Ya Mahn
Dryden Ontario
I'll get this thing dialed in yet! I have a vibration at about 9200-9500rpm which translates into about a quarter-half throttle roll on? It feels like the track is ratcheting but a lot less intense. The track is tight, the primary supercharger pulley is within spec and the secondary pully is also in spec. It kinda feels like a shudder. Any ideas?
New track drivers? No there are less than 2000 miles on it but its a thought. I'll check them out
Check the bearings on your jack shaft and drive shaft.
Thank you for all the suggestions, I found out it was the primary belt on the supercharger was a bit loose causing it to skip at 9000rpm.
