What RPM's are you running??
shanksRX-1
Pennellville, NY
2010 Apex
LOCATION
Pennellville, NY
With the sled on low boost and WOT accelerating Im running between 9500 and 10,000 on my rx-1 with a 25 tooth top sprocket. My buddies warrior with same bender stage II turbo and heel clicker clutch kit but 24 tooth top sproket (longer track) he is running 10,500-11,000 Whats everyone else running and how is it best adjusted?? I would like mine to run where it should 10,000-10,200 is ideal..
10,000 is ok i have run my sled at 1000 foot speed runs same speeds from. 9,900 rpm to 10,500
Skydog
Whats the best way to adjust it?? I took my tip bolt out of my heel clicker weights now I have the middle bolt with 3 washers and heel bolt with 7 washers installed. I thought this might make it pull a couple more R's I would be happy with 10,000 but its usually around 9500-9700
This is the problem with high low boost switches, you can't have it clutched for both.
I suggest you pick a boost level that is safe for the fuel your running then clutch the sled to that power level.
Shoot for 10,200, If you need a turbo clutch kit give me a call 203-753-7223
I took the sled out and with the tip bolt gone in all 3 weights and the others in its running right around 10,000 in the powder. Its hard to tell cause I cant get a good straight packed trail its all powder and tracks in every direction on the lake... Im running about 5lbs of boost right now on low with the fuel im getting and since im new to turbos im working my way in...
