burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
I recently switched from stock Yamaha primary weights to Supertips. I was running 11,000 rpm at WOT. Apparently, this was costing me some top end speed. So, I wanted to get down to 10,700 -10,800 to find the sweet spot. So, I started with: heel=Tungsten insert & 1 washer; Mid=Empty; Tip=1 washer. This set up brought me down to 10,500 WOT. Does anyone have experience to suggest what to change to find 10,700-10,800?
My sled is currently in the UP, so I am limited on my test and tune time. Worse case, I can live with this. But if someone has a good suggestion, I am willing to try it on my next trip.
Thanks.
Thanks.
Remove the tip weight.
canadian nytro
- Dec 3, 2009
- Port Perry, ON
- 2011 Yamaha Apex
2002 Yamaha Viper
What MrSled said, I find that 1 gram in the tip is good to move rpm's 100 or 200 overall.
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
1980 Exciter 300
Thanks. I'll give it a try.
