revvystoke
I picked up a high mile 2009 Apex LTX. It was well taken care of and I can see nothing wrong with it. I bought a used Vector of the same year for spare parts. I need to know what I should replace before it starts to snow more up north here.
I ordered;
Copper donuts
New hyfax
New fluids
two new belts and plugs
Does anyone sell clutch rebuild kits or do I need to piece one together with OEM parts.
I have KYB piggy backs and a spare mono from the vector, I want them rebuilt and revalved, who does good work with these shocks? How tall is the tallest Yamaha windshield? Or should I look aftermarket for the best windscreen.
I ordered;
Copper donuts
New hyfax
New fluids
revvystoke
Forgot to add, I plan to order all new bearings for the drive train when I order clutch parts.
Are the wheel bearings in the skid replaceable? I noticed a couple were missing seals.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Your best bet is to just read the "Sticky's" at the tops of each section, read the TY Tech section at the top of this page and do a search here or Google with anymore questions.
Any problems that arise, then ask as most will be eager to help.
http://www.totallyamaha.com/snowmobiles ... Index.html
Ak Yammy
All of the above and check the a- arms for slop may need a bush kit if they are bad. How many miles?? If it's the original driveshaft with around 10k it's living on borrowed time.
revvystoke
4800mi or so on it. Shocks are in need of lovin, who does good work with these.Ak Yammy said:All of the above and check the a- arms for slop may need a bush kit if they are bad. How many miles?? If it's the original driveshaft with around 10k it's living on borrowed time.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Curious... with only 4,800, why are you rebuilding the clutch?
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
AT 4800 I would look at all the stuff mentioned but mine required very little for the first 10k miles then did all bearings with donuts and track and is still a cool fast reliable sled.
Yamadoo
Yamadoo
revvystoke
Rollers have rust, looked dirty, I usually change all drive springs on my sleds yearly.THKSNOW said:Curious... with only 4,800, why are you rebuilding the clutch?
Ak Yammy
My donuts werent even close to being bad at 5k I thought you had many more miles. Pioneer did a fantastic job on my shocks if you want to spend more $$ go to Hygear.
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
My donuts wre shot at 4600 miles
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
i went thru donuts on my 07 every 3500 miles.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Most original skid wheels had non-replaceable bearings, not sure if or when that changed.
That Vector engine you have would be a great Rhino side x side upgrade! hmmmmrevvystoke said:I picked up a high mile 2009 Apex LTX. It was well taken care of and I can see nothing wrong with it. I bought a used Vector of the same year for spare parts. I need to know what I should replace before it starts to snow more up north here.
I ordered;
Copper donuts
New hyfax
New fluids
09nytro
That's not high miles , it's just getting broke in....revvystoke said:4800mi or so on it. Shocks are in need of lovin, who does good work with these.Ak Yammy said:All of the above and check the a- arms for slop may need a bush kit if they are bad. How many miles?? If it's the original driveshaft with around 10k it's living on borrowed time.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
revvystoke said:Rollers have rust, looked dirty, I usually change all drive springs on my sleds yearly.THKSNOW said:Curious... with only 4,800, why are you rebuilding the clutch?
Same year sled here that I just got. Same surface rust on rollers? Wonder why cause I never seen that on my SRX. I put silicone spray on them but they turn easily regardless. Does it affect performance?
