What turbo?!?!
AllagashX
Allagash Maine.
Wanting to turbo my 08 Ltx this winter, I want minimal lag and 250ish hp... Needs to be reliable on trips alone and pump gas! Any help would be nice. I plan on spending no more than $5000.
I run a cpr kit and got 270 HP @ 14 lbs. 245 hp @ 12 lbs pump gas running stacked head gaskets, But that didn't happen for under 5k
Look to be around 7500 to get that.
CPR has been terrible for me, called lots of times trying to get stuff etc with no luck. I would have to plug Dave at powderlites as he is setting the industry benchmark right now. RB3 is awesome.
Can you/do you want to do the installation yourself? Is $5K is a firm price limit to be up and running with boost including gauges and install as well? Give me a bit more info and I'll make some suggestions...
Dave is doing great things now, I went to him to upgrade my turbo and get his double down pipe. And I will have the RB3 for the improved mapping and the ability to take timing out on higher boost. At first I had nightmares with CPR, but jeff stepped up and took care of the issues I was having and I respect him for it.
I had my header cracked after 300 miles, and I left 1 message on his phone about it. 2 days later he called me back and is working on it now. No Problems other then that.
I only gave the advice on my experience. And that is the CPR kit worked great with great HP. Other then the crack everything was perfect. Which the crack was caused by a bad weld from what I saw. Hey No one is perfect all the time.
Just my two cents
Well i can spend more, I dont know the price's etc.. I was lookin at the new Mcx kit 290 hp? I dont know the price or have any feedback,
I could probly install myself. what would having it installed cost at a dealer?
