charger0926
- Sep 3, 2008
- Elk Grove, CA
- 2012 nitro mtx 162
what are the part #'s and quanty of bearings i need to replace on my 07 attak i know there two different kinds 6205 ? i think i dont need the yamaha part # just the aftermarket bearing numbers
thanks
thanks
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
On my 06 apex RTX(short track 121")...(when i had spoked accessory idlers)
Rear axle wheel bearings
42mm OD X 20mm ID X 12mm wide
# 6004
Idler wheel bearings(if replaceable,like in spoked accessory wheels)
52mm OD X 25mm ID X 12mm wide
# 6005
Upper Large wheel bearings
52mm OD X 25mm ID X 15mm wide
# 6205
Dan
# 6004
# 6005
# 6205
Dan
charger0926
- Sep 3, 2008
- Elk Grove, CA
THATS A DIFFERENT REAR SUSPENSION IF I AM CORRECT
SAME NUMBERS AND QTY. AS THE MONO SKID?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
charger0926 said:THATS A DIFFERENT REAR SUSPENSION IF I AM CORRECT
should be same as far as bearing part numbers,but im not sure what idler wheels you use...i got rid of crap stockers from day one,i dont think those bearing were replaceable on stock originals.
qty?....you need to count how many you need....if they still roll easily they are fine...
Dan
