johnketch
when i start my sled is the temp light supposed to be on for a minute?
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
Yes it is the worm up cycle you need to let it worm up then the light goes out and your ready to go.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
yap
johnketch
ok thanks , headed uo north now seeya
shanksyamaha
I think the light goes off when the coolant reaches something like 80 degrees. I like to let it run for 3-5 minutes after the light goes out.. These big 4 strokes like to be warmed up nicely before riding...
I dont think the throttle will respond untill the light goes out.
sledneck22
On my 06 the throttle will respond even if the light is on. One night I had mine parked in the back driveway and had to move it really fast for something... I can't remember what or who it was off the top of my head now... and i just started it and moved it right away with the light on to get out of the way but then just let it run for 5 minutes after I moved it to make sure it got warm before shutting off and so I didn't foul any plugs. So after that hellacious run on sentence - back to work. haha
copo427ss
you will be limited on rpm until the light goes out.
I thought I read or heard something about drivablity or rpm when the light is on.
Mtn-Track
bottlerocket said:I thought I read or heard something about drivablity or rpm when the light is on.
Yep. Hit the flipper with the light on and it usually fowls the plugs, quits, then won't re-start until you pull the plugs!!!
snerkman
The manual says you can drive it if you have to before the light goes out.
Re: Apex question
Its for oil pressure not temperature,sleds not even close to being warm in 20+ sec.i wait another 5min after light goes out before takeoff..johnketch said:when i start my sled is the temp light supposed to be on for a minute?
Re: Apex question
I know it has a temp symbol on it but at that moment on cold start-up its for oil-pressure.tomanytoyz said:Its for oil pressure not temperature,sleds not even close to being warm in 20+ sec.i wait another 5min after light goes out before takeoff..johnketch said:when i start my sled is the temp light supposed to be on for a minute?![]()
In the morning when its cold my light is on for several minutes and you think its oil pressure... lol
shanksyamaha
bottlerocket said:In the morning when its cold my light is on for several minutes and you think its oil pressure... lol
I have noticed too that the colder it is the longer the light stays on. when I start my sled in the summer the light is only on for a couple seconds. In February it stays on for a minute or more. Depends on how cold it is when I start it..
