4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I'm a gauge freak and want to add a digital oil pressure gauge. I have a 2005 Vector ER.
Question is where do I pull the pressure reading from? I assume it the same "port" that has the stock oil pressure "port". But where is that on my sled?
TIA for the help!
TIA for the help!
wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
Well the one on my apex is on front of block 1/2 way doen the front behined battery
Would assume vector is the same
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
The Vector engine is turned around because of the lack of a reduction gear. Have Apex Vector and had a Fx Phazer It would be on the back side towards the tunnel.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
There's a 6mm x 1.0 plug (10mm headed bolt) on the intake side of the cylinder head, by the #3 intake boot that is pressurized.
You would need a 6mm x 1.0 to NPT adapter to screw your oil pressure fitting into.
https://locknlube.com/products/m6x1...nu1EAZzmcbCIGWuf1uVeO0xgFkmRBNcUaAivlEALw_wcB
