where to grease???
I have always pulled the clutches and inspected/cleaned them but have not done anything with the Jacshaft ot Driveshaft bearings. I think it's time though. I know I am pushing 6-7Kish. Anyone with more info on what to do? Clean the old grease out with what and regrease it how? Will something like a dental tool set work for poping the seal and what is the trick with getting the seal back on? It this easier than I think it is? I'm one to usually replace a bearing and not repack it...but in this case I would repack if I know what NOT to do.
Thanks for any tips guys....
I am going to assume that the secondary is the "big" clutch closest to the driver? Looks like I should grease this stuff too.
SNOWDOG said:
I too would like some details about popping the bearing seals on/off. thanks
A very small flat blade screwdriver will do the trick. try to get it in at the outside edge of the seal and lift up, it should pop right off. It can be pushed back by hand with your fingers.
Bill
