Which breather box solution is best on RX1 turbo -03?
capri
Sweden
The lightning pro works perfect if you weld a fitting on the breather outlet and run a hose to the bottom of the belly pan and ad the filter there.
That way if the sled is upside down there will be 0 oil leaking out and there is no danger of setting a frond mount on fire ( been there )
There are baffles inside.
Capri, you pay the shipping from Alberta Canada to were ever you are in Sweden. You can have my lightning pro box. I purchased it couple yrs ago to try to fix my blow by issue, which turned into an engine rebuild. Now it wont work for my mid mount set up, as handle bar column goes were the box is suppose to be mounted.
Thanks Red, that is very kind of you!. :jump:
Just tell me how much you need and i will send it over with Paypal if that is ok?. Send me a PM when you can.
I also have the steering column forwarded, but i will make it fit somewhere.. ;)!
