Which clutch kit seems to give the best results?
Jack_Shaft
N53.486 W59.860
Just wondering what you guys have been running in the way of clutch kits.
I have a stock RX-1 and a turbo RX-1 that will be running anywhere from 8psi to 15psi of boost (manual boost controller) and I was wondering what you guys have been using in your primarys/secondarys.
Is the heavyhitters clutch kit all that it is cracked up to be? I am in no way brand biased, so suggest away!
I am very happy with my HH kit from Matt but I am not into clutching and was the easiest way to go especially when I added the filters and only needed to adjust the weights rather than replace them. I would think he and Simon would be right on top of the turbo due to all the work they have done on them.
In the same breath many have been happy using Yamaha weights or Dalton systems, just depends on your skill and knowledge of clutching.
Jim
for top end rr bed running nothing ive seen beats stock setup but ive seen "quick" setups from most all others but our buddy with stock everything pulls us on top end if trail is hard
We had great luck with CPR products on our VIPERS. So Im going with CPR on my new RX-1. I will post how it performs, compared to stock set up...
