Clutching or Clutch kit for 04 Rx-1
Srxspec,It would be great to be closer.I'm not at the end of the world,but you can see it from here.
Pick 192 good to hear from you Paul
Frostbite ,good to hear from you too.Actually no,i havent ,I seem to have to jump around to different things more often than I'd like to .Clutches on so many models changing things like RER,(now another new one from ski doo this year(both primary and secondary),direct drive cats,new sec and fixed pin weights last year,you know constant change.It is true though,I probably will spend a bit more Yam time,as i will be fooling with my own application when possible.
I appreciate any and all input you gave in early testing of the mountain version,as all info is good info. What I for sure did find out in 03 was that no two mountain rx sleds or riders like the same thing,LOL.It seems that one guy will be a hillshooter and only cares about climbing,another is only at 4000 ft and trail rides,another only wants best performance above 9000'(and no 2 guys describe the same results). There is not a hill higher than 2000 ft for thousands of miles from here,so its definately not something that I have good personal experiance with.
I have read thru some good info on this site and I'll visit with questions,Thanks.
