Which track............
Black 1000
Beaverton
I have to replace the track on my 03. I have a Camo 9830 now and it has two good stud pull throughs. I was very happy witht is with 144 studs. What else is being run and how do you like it?
I have 5 friends, two of them with RX-1's and they all replaced their worn tracks with Ripsaw's. What a difference it makes, unless you are riding on pure ice, you don't even need studs. If my track wasn't so new (750 miles), I would replace it too!
I am replacing mine with a 136 ice ripper
I am thinking of the 1" ripsaw already drilled for 144 down the middle. Will the double backers fit with that track and stud hole configuration?
i did the 1" predrilled predator (awesome), 1" ripsaw maybe even better. had 1.25" ice ripper was alright until the rubber wore down around the studs and had so much grip the lugs started flying off !! camoplast was great and warrantied it, i would not recommend it to an aggressive rider !!
