Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
Which Wahl drivers should I go with and do I have to worry about them causing any other problems?
I have an 06 Nytro that I am stretching to a 144 and am installing a fully clipped track. I'm thinking that now is the time to install new drivers. Which one's should I go with? I'm thinking of just replacing my outer ones with the flat, cheaper ones because that seems to be the setup that the new sleds are using
ahicks
I don't see the reason for changing drivers unless you are going to the extros - the one on the left. If you do that, generally you just run the 2 of them.
Not familiar with the ones on the right. Haven't seen them in use since the days of cleated/metal tracks.
dhkr123
The ones on the right are generally used IN COMBINATION with the stock drivers. You end up with a lot of stuff on your shafts.
I'm finding now that there is actually better track selection available for 2.86 pitch. Have a look at XC PRO tracks... first actually impressive looking track since predator. In fact, I just ordered a 146" XC PRO and a set of 8 tooth 2.86 drivers (like the ones on the LEFT) for my RX.
http://www.camoplast.com/tracks/tracks/xc_pro_over.html
Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
I already have the track. It's an OEM skidoo track, 2.52 pitch from tracksusa
One thing I read about using the right side ones along with the center stock driver is if any of them twist slightly on the shaft, the extros will get out of timing with the stock ones. I'm ordering the left ones
Brad
Brad
