whistling noise, exhaust????
bobber
Ft McMurray Alberta
Out for a ride today and machine started to make a 'whistling' noise at idle and lower speeds. Appears as if noise is coming from under the handlebars, more pronounced when R/H side panel is off. Think there is an exhaust leak somewhere.
sleddog66 said:
Intake leak....air box clamp loose on a boot?
Noise is coming from the exhaust side of the engine. Did quickly look around the intake side at first but traced noise to rear side of engine. Going to go out to garage in a few minutes and look some more. Machine still under warranty so not too concerned with that part. More so curious if anyone else heard similar noise. Almost like an auto's alternator belt when worn out.
