who installed the AC 151" skid from 1M?
Jonny Rocket has a 151" 1M skid under his Turbo RX-1. His 159" track would not fit but his 162" Maverick does fit. I imagine he'll add more to the story.
Frosty
Yes, I have a 151" 1M skid that my 159" track did not fit under. Way too tight. I had the tensioners all the way out and no go. But, at the time I did have 9 tooth 2.52" pitch extros and the 8" rear idlers. So it might fit w/8 tooth 2.52" pitch and 7" rear idlers.
Now with the 7 tooth 3" pitch drivers and 8" rear idlers, the 162 is almost too much. I only have about 1/4" left on my tensioner. Go figure.
151-159
I have a 151 skid in my rx with a 159. I had to move the front holes forward about 3/4" from the stock, and made a extra set of holes in the homemade rear drop brackets. You can make it work, but the 162 would be better!!!
