I've been reading through all the clutching info on this forum and have not seen anyone say they've tried what Yamaha suggests.
Are their recomended set-ups to general????
I'm riding a stock 2009 Nytro MTX.
I've been reading through the 2009 FX10MTRY, and the 2010 FX10M53SZ / 62SZ tuning specs in the service manuals.
Their recomendations for 2010 have been updated from 2009 for the 153 track length. For a stock sled, for 6-8500' elevation, for 153" track, the 2010 spec is:
-8FS00 weight with 2.4 gram steel rivet in outer hole
-G-W-G primary spring
-16.5mm rollers
-White secondary spring with 60 degree pre-load
-39 degree cam
-20-40 gearing
They are saying 3400 rpm engagement & 8750 rpm shift.
The only change for the 2010 set-up is the white 2ndary spring(2009 it was pink) and the 60 degree pre-load(2009 was 70).
Has anyone tried the 2010 set-up? What do you think about it? I plan on giving it a try next week-end.
-16.5mm rollers
-39 degree cam
-20-40 gearing
