vtr1
- Aug 30, 2006
Will the warrior suspension bolt into the RX1 or do I need to Modify it?
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
adirondac blue
The mounting pionts in the rear are different, it will not bolt in.
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
You'll most likely have to use the Warrior drop brackets.
vtr1
- Aug 30, 2006
Thanks for the info Sounds like an extension kit is the easiest route. does anyone know if you can go from 121 to 144?
Jack_Shaft
An proper 136" Warrior skid is far superior to an extended 121".
It'sa not hard to relocate the rear drop brackets, just measure the round-about location that need form a stock Viper, drill out the four rivet, remove the two bolts and move that sucker in the tunnel.
It can be easily done with the stock RX-1 121" brackets, you just have to move them.
