srxguy
Will a stock 04 warrior skid bolt in a 03 rx1 useing the existing 03 brackets??...thanks
srxguy
Anyone??
yes, and no, the rear arm all be it the same arm is set back, the fra is also set back to match. it will all fit but you will want to find a worrior and measure the holes. other than the rear tunnel extension and the holes, it will bolt right in.
srxguy
Ok, thanks
srxguy
I just need to find someone with a warrior to take measurements!!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You should be able to transfer both rear mounting points back 7.5" and everything should line up perfectly.
srxguy
...Thanks alot!!Srxspec said:You should be able to transfer both rear mounting points back 7.5" and everything should line up perfectly.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
I have a set of stock drop brakets Maxdlx
