Will an xtx skid bolt right into an 08 121" ?
snomaniac
jenison, michigan
Have a line on an xtx skid, wanted to know if it will be a straight bolt on to my 08 nytro 121 or if mounting holes need to be changed. I know I would need a tunnel extension. Let me know before this deal disappears. Thanks.
It won't bolt right in. The XTX has the newer tunnel and the rear mount will be further back. It will be a difficult project, you might be better of getting rail extensions from OFT.
....and yes you'd need a tunnel extension
xtx
The skid won't come close to bolting right in. The front holes need to be closed and redrilled. I can help with some measurements, also you will need the stock XTX drop brackets which will need mostly all new holes drilled for the two bolts and rivets. I done this over the summer. It was difficult. By first looking at the front mounting locations you would assume it would work, but the top front suspension arms actually will be rubbing the track. PM me if you need any extra help.
