Will Doo 10 tooth extros work with 121" x 1.25" tr
bradfr
Rochester NY
Recently bought a nytro and I am having all kinds of ratcheting issues. Every time I punch it from a dead stop it ratchets. I have tightened the track quite a bit and I still get some but not as much. I have read a lot on here about putting doo extros on but most say to get the summit 9 tooth extros because of potential rail and bulkhead clearance issues. Has anyone successfully ran 10 tooth doo extros with a 1.25 studded track?
Bradfr,
try this first, make sure your chain tensioner is installed properly and tightened to the correct tension. Loosen the jam nut, fully hand tighten bolt and then back off 1/4 turn back, tighten jam nut.
I had this same problem off and on for a year and found out my tensioner was partially broken. fixed it and never had a problem since.
Kope.
