bigcountry
anyone know if a nytro windsheild will fit on an 04 rx-warrior?? i put a 7 inch fly riser with a set of fly aero taper bars on and i have the low cut rx windsheild on now and i can't get my handgaurds to clear it. any suggestions??
SISCAKIDD
otis
Take a dremmel tool and cut it to what clearance you need. The trim comes off and you can reinstall it when you're done. If you like the nytro shape go copy it. If you screw up you're not out anything.
I did it to mine when I added a 5" Rox riser and it works and looks great.
Otis
Otis
VForce_NS
i just ordered a nytro windshield and handguards for my RX. never got them on yet
bigcountry
unfortunatly i do not own a dremmel tool yet, do you think a jig saw with a metal blade would get the job done??
Jack_Shaft
Sure, just file the rough edges before you put the edge trim back on.
otis
Test an inconspicuous spot first. I have tried to cut Plexiglass with a jig saw and the coarse blade just chipped the heck out of it.
Otis
Otis
ptt
Guest
wind shield
Mark out with tape how you want it to look, then use tin snips. I would think that a jig saw might crack the shield.
