windshield lower than 10 inches?
RTX Meirda
ELMIRA ONTARIO CANADA
Does anyone know where you can buy a short windshield. The smallest one yhat I can find is 10 inches tall, I would like a shorter one.
I used to have an SRX....I like the fresh air!
Even though I had an SRX as well and really enjoyed the lower shield I like the shield on the RX-1 even more. I like to wear the motocross style helmet and on the SRX there was just toooo much wind noise and turbulance so I did not wear it as often. With the RX-1 I wear it all the time. Only on -30c and lower do I wear the fullface snowmbile helmet with the electric shield.
I wear a moto x style helmet as well. I really like the tug that the wind gives on my helmet on the SRX at 100 mph. I wear a NO-FOG neoprene facemask and headband. Works well and visability is great!
LazyBastard said:
There's nothing stopping you from cutting your windshield down. Pull off the black strip around the edge, cut down, and use CONTACT CEMENT to glue the strip back on.
I saw a RX-1mtn just like this last year. The guy made a fairly short arch from the outer point of of the headlight and glued the trim back on I will see if I can locate the picture I took of his sled for you to get an idea of what it looks like.
