z28rx1
need help with wiring under the handlebar pad. like a jackass i took the handlebars off (to paint the tank cover) and while unpluging all the connectors i didnt lable the single leads for the warmers. now i cant figure out which goes to which one because they are single leads. dont want to try unless sure (and screw things up) any help? 04 rx1
LazyBastard
Doesn't matter since they all go to the same place.
z28rx1
well we put all the blacks to gether and the 1 with the stripe with eachother, they dont work and the eng light flashes 2 times off then 2 ect. whats up with that?
LazyBastard
Unless you did something wrong with the colored plugs or didn't actually connect them, it shouldn't care. Black plugs go to black plugs. White to white, blue to blue, etc.
z28rx1
everything works good thanx loads
