crusher1
- Jan 15, 2009
08 FX, OK, no power to dash or starter 98% of the time. I've replaced all the relays by the ECU, the starter relay had green fuzz, took it apart and cleaned it, tore apart the key switch and it was fine, checked small fuses by brake rotor, main fuse and fuses on starter relay too.
Battery is good, I turn the key on and wiggle everything, tap on everything and nothing.
The plug to the starter relay has 4 volts with the key on to the BL/WT and R/WT and get nothing to the R/GN in any key position. I assume I should get 12 volts and get power to the other terminal in the start position ?
Key switch looks good, not wore out, any ideas ?
I dielectric every thing at least once a year.
Old Thumper
OK, somebody has to ask...
Kill switch ???
Kill switch ???
crusher1
- Jan 15, 2009
I haven't tried the kill switch, thats next I guess but my dash should still light up, yes ?
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
If the kill switch is down there shouldn't be any power to anything on the sled.
canuk77
The black wire on the starter relay that goes to the starter,take the wire off and give it 12 volts and see if the starter cranks over.I have seen it twice when the starter packs in it kills the sled completely.There is also an updated starter relay for these sleds.
crusher1
- Jan 15, 2009
Yes, I can crank it over crossing the terminals, would this relay effect the dash display too ?
canuk77
According to the wiring diagram the power goes through the relay then gets distributed through out the machine...
crusher1
- Jan 15, 2009
Thanks, that helps too knowcanuk77 said:According to the wiring diagram the power goes through the relay then gets distributed through out the machine...
taxiguy
- Jan 4, 2011
I have an 08 fx too and this year same problem in th emiddle of no where got lucky wiggle the wires from the ignition switch where they plug into the wiring harnes , and been running since ..I think its the connection in the plug from the ign switch ???
- 6K
