grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Put the battery on a charger for several hours then have it load tested. Autozone will do it for free. You can also load test a fully charged battery using a meter to measure the voltage drop under a load. To do this pull the ignition fuse so the sled doesn't start then roll the starter while measuring battery voltage. If the voltage drops below 9.2-9.3 volts then the battery is bad. If the battery is OK and you jump across the starter relay posts to energize the starter directly and it doesn't roll over then the starter is bad.
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
I jumped it off my truck and it took off. I got another battery just so I don't have to worry our west
Sent from my XT1254 using Tapatalk
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
I forgot to say right from the get go when key turned on the display would flicker and the relay s would click. The starter never would turn over. Voltage must have been so low or would not even try.
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
Thank you all for the replys. This is a great community
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Thanks for letting us know.
Pete
Pete
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
I got a new battery and tried to charge the original but it won't take a charge at all. 9.8 volts is what it reads. I don't think I left the key on so what else could have killed my battery in a matter of 3-5 days??
herndonp
- Nov 28, 2012
- Freedom,NH
Probably a bad cell. You can check your charging circuit with the sled running with a meter. Should be 13-14 vdc at the battery terminals.
Pete
Pete
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
OK. With key off. New battery is 12.5 volts. I thought it should be higher
herndonp
- Nov 28, 2012
- Freedom,NH
Thats fine. Just start it up and measure voltage at battery terminals.
Pete
Pete
herndonp
- Nov 28, 2012
- Freedom,NH
Did you put the new battery on the charger before putting it in the sled?
Pete
Pete
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
Yes. 1.8 amps for 10 hours like the battery says
herndonp
- Nov 28, 2012
- Freedom,NH
One other thing are you using a newer style charger i.e. CTEK or similar ?
Pete
Pete
herndonp
- Nov 28, 2012
- Freedom,NH
Then just start it up and measure the voltage at the battery terminal to be sure the machine is charging your battery. Should be @13.5-14 Vdc.
Pete
Pete
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
Yep got 13.5
herndonp
- Nov 28, 2012
- Freedom,NH
Perfect
