Working on installing my bender turbo on my Apex????
golfaddicted
Spokane, Wa
I've got most of it figured out, but have a few questions. I have two small "k&n type" air filters. I assume one of them goes to the crankcase breather that used to go to the air box. Where does the other one go? Also, the fuel controller has a clear tube coming off of it. I have a picture that shows where it goes and I'm OK with that, however it has a Tee off of it. Where does that Tee too? Also what do I do with the electrical connector that went to the air box on the left hand side and the small line that went to the air box on the right hand side? I would sure appreciate some help. I'm getting close and getting excited.
The second small K&N style filter was for the IAC port, but I believe there is an update to that from Full Power Perfromance and I don't think it used anymore? Call FPP...
The T in the sense line for the controller is for a boost gauge, cap it if not using one.
The connector is for your airbox temp sensor, you need to remove the sensor from your old airbox and keep it plugged in so you don't get a code, ziptie it off to something so it doesn't flop around. The sensor is NOT used in the new intercooler airbox as it is not designed for postitive pressure and will blow out.
The small line is a vent line, I am not sure but call FPP.
That is an awesome kit.
Mory
Yeah, I got all of those figured out last night except the IAC filter. Can you describe where the Idle air controller is or a picture? I sure appreciate the help. I'm getting excited now. Gotta go out and finish it up this morning.
