marsh14
I am ordering a super-q for my xtx. Should I break it in before changing the exhaust?
snoxracer183
Break it in how you're going to ride it!
marsh14
The exhaust won't make it too lean during break in? What is this co adjustment I keep reading about?
BLUEBALLER
- Jan 29, 2005
it will be leaner. I have the ultra q on mine and noticed it. you definately will. I was thinking of trying the CO adjustments as well.
If it were me, I'd break it in stock - hard - then install the exhaust and play with the CO levels or add a fuel programmer.
lotsa popping on decel. I think she's a little too lean. Sounds awesome under load, but drony around 40 - 60 mph. and the decel popping drives me nuts.
other than that, I like it!!
marsh14
My zx-10R with a Jardine pipe on it pops and backfires on decell and I love it.
BLUEBALLER
- Jan 29, 2005
my R6 sounded good on decel. too with an S4. trust me, this is different.
SledderSteve
This thread should help answer your second question: http://www.ty4stroke.com/viewtopic.php? ... adjustmentmarsh14 said:The exhaust won't make it too lean during break in? What is this co adjustment I keep reading about?
marsh14
Daranello
Suspended
The tail of the 2 new 07 attak break in's. Both sleds bought new at the same dealer and both riders are the same weight.
Sled#1 0miles-100miles wide open runs on the lake well over 120mph on the dream meter
Sled#1 0miles-100miles By the yamaha book 100-300miles Motoman and yamaha still taking it easy but doing the odd short full speed runs
Resuts after 2000miles ....exact exact same top speed, the only diff he burns oil, I don't not a drop of oil is burnt and I now hold her wide open for long runs (10-20miles runs). he burns a half a quart every 500miles
Nytro12
I found this site pretty good. What do others think?
http://www.mototuneusa.com/break_in_secrets.htm
I'm planning to break it in in a wide open space where I can accel and decel hard. Changing the oil after break in and not using synthetic oil during break in
Deadman
So, the one you broke in hard or soft is the one thats burning the oil?Daranello said:The tail of the 2 new 07 attak break in's. Both sleds bought new at the same dealer and both riders are the same weight.
asphaltkitty
break in by the book, it will run better , better gas milege,
Daranello
Suspended
Deadman said:So, the one you broke in hard or soft is the one thats burning the oil?Daranello said:The tail of the 2 new 07 attak break in's. Both sleds bought new at the same dealer and both riders are the same weight.
hard burns oil, by the book and motoman perfect no oil loss
Eagle1
great now I cant even start my sled in the garage
man this is gonna be a long wait til winter!
What do you all think of change oil at 200 -250 miles instead of 500 miles? 500 miles seems like a long time with all that metal floating in your oil
SledderSteve
Sure you can, just be sure to do a complete heat cycle where you let the engine come up to operating temperature then cool completely down to ambient before starting it again. It was actually a recommendation to do this when we got the RX-1's in '03. Might have been a bone they threw us since they knew we were going to start them anyway. Seems so long ago now.. The biggest danger in garage starting is not getting the engine up to temp and fouling plugs.Eagle1 said:great now I cant even start my sled in the garage
As for changing the oil, go for it, the 500 mile mark is just a recommended minimum, clean oil isn't going to hurt your engine.
